TwinTurbo.NET: Nissan 300ZX forum - Re: Prob something to do with alt+idle pulley....more
Subject Re: Prob something to do with alt+idle pulley....more
Posted by FASTESTZX on March 10, 2010 at 6:04 PM
  This message has been viewed 66 times.
In Reply To Prob something to do with alt+idle pulley....more posted by SilverSlickTopTT on March 10, 2010 at 12:56 PM
Message :Think how the system works as a rotating unit. All three
are dependent
:upon eachother to work. If alternator is noisy it has to be
the rear
:bearing that is housed in back of alt. Its the only thing
that can cause
:friction due to wear thus making a noise. That said the
bearing rides on
:the rotor and stator shaft if that shaft is pulled to hard
at an angle it will
:put that rear bearing in a bind and there is prob. Question
is what is
:pulling on the alt pulley to do that? So typically its the
idle pulley because
:its the weakest link in that system. That pulley should
have no wiggle
:movement nor should it have a rough roll to it. But,
anumber of other
:issues may be at play...the alt bracket, the actual bolt
that hangs the
:alt...is it outta wack. Like u said fan clutch ..does it
seem to work ok. Just
:start checking but usually its that damn silly pulley!
